February 19, 2013, 12:25 |
Turbulent Kinetic Energy
rietuk
I am conducting a CFD validation against some experimental data. I am trying to compare turbulent kinetic energy as I am given the RMS of the fluctuating components for the 3 directions in an experimental report. Am I correct in using the formula k=0.5*(Urms^2+Vrms^2+Wrms^2) to calculate the experimental TKE? When I have done this the experimental and CFD TKE results are orders of magnitude different but the pressure profile is similar Thanks for your help |
February 19, 2013, 14:16 |
k' = u'2 + v'2 + w'2
February 19, 2013, 14:45 |
rietuk
So if I have the RMS of the fluctuating components does this equal the u'2 etc. as you mentioned or is it or does it need squaring to equal that? Thanks for your reply |
February 19, 2013, 15:32 |
Filippo Maria Denaro
Rep Power: 71 |
The most important fact in the comparison, is that you must use the same fluctuations that means you must use the same average in the experimental measure and in the numerical simulation!
February 19, 2013, 15:39 |
rietuk
Ok
From CFD I have Turbulent Kinetic Energy in J/Kg From experimental I have RMS of fluctuating velocitities u~, v~ and w~, all squared and multiplied the sum by 0.5 to give k. Is the k comparable to the Turbulent Kinetic Energy from the CFD? Thanks for your help, much appreciated! |
February 19, 2013, 15:59 |
#6 | |
Rep Power: 71 |
When you decompose your velocity in an averaged and a residual component, such a decomposition says you nothing if you don't define which is the averaged velocity... Generally, I suppose that you have in the experiment a Reynolds average, therefore your CFD formulation must reproduce the same average |
February 19, 2013, 17:32 |
rietuk
That makes sense, thank you
The experiment has an average velocity of 1m/s to give the Reynolds number of 40000 To match this Reynolds number the CFD average velocity is 15m/s How do I scale the CFD TKE or experimental fluctuating velocity components so when I calculate TKE the experimental and CFD TKE are comparable? Thank you! |
cfd, experiment, tke, turbulent kinetic energy |
question about turbulent kinetic energy | junker4236 | Main CFD Forum | 19 | April 19, 2017 04:46 |
LES and total turbulent kinetic energy | Boerge | FLUENT | 1 | September 8, 2012 11:41 |
LES of periodic pipe centerline turbulent kinetic energy | smehdi609 | OpenFOAM | 0 | November 30, 2010 23:59 |
what's the macro of SGS turbulent kinetic energy? | lcw | FLUENT | 1 | June 13, 2006 03:08 |
Turbulent Kinetic Energy | Olga | FLUENT | 2 | October 11, 2002 15:05 |
