two-phase flow with variable surface tension
Old   May 18, 2006, 22:10
Default two-phase flow with variable surface tension
yf
hi there... i am looking for commercial software that c an perform two-phase flow with variable surface tension (marangoni effect). any suggestion is greatly appreaciated. thank you very much. yf
Old   May 19, 2006, 09:58
Default Re: two-phase flow with variable surface tension
Pei-Ying Hsieh
Check out www.openfoam.org. You get source code, so that you might be able to do it yourself. Currently, it has timeVaryingConactAngle, that is, wall contact as a function of time. It should be quite straight forward to make the surface tension as a function of time (or location). But, I have not tried this myself.
To make sure of this, contact www.opencfd.co.uk.
Pei
VOF & Variable Surface Tension in FLUENT SeamusTCD FLUENT 13 June 18, 2022 01:51
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 11:44
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Looking for software for free surface flow Eric Jiang Main CFD Forum 12 December 17, 2007 23:39
