history effects of turbulence could u please..
Old   May 22, 2006, 09:14
Default history effects of turbulence could u please..
bajjal
It was mentioned in Jonas larson paper ' Two -Equation Turbulence Models For Turbine Blade Heat Transfer Simulations' that Navier stokes solver with algebriac turbulence models will give good results for simple cases but for cases with seperated regions ,shocks and high turbulence levels Navier stokes solver with transport turbulence models is good since it account for history effects .so , i want to know what is this history effect .
Old   May 22, 2006, 13:42
Default Re: history effects of turbulence could u please..
Jonas Larsson
History effects in this context means that the turbulence in one point is dependent on the turbulence upstream of that point, ie what happened to the turbulent fluid before it reached the point, ie the history of the turbulence.
Algebraic models are local in the sence that they prescribe the turbulence in a point as a direct function of the local average flow-field in that point. Two-equation models account for history effects in the sence that they convect and diffuce both turbulent energy and a turbulent dissipation. So if you had something upstream that generated a lot of turbulence (like a separation) a two-equation model can account for this, whereas an algebraic model usually can't.
Old   May 24, 2006, 01:14
bajjal
Thanks Jonas the way of expressing is very precise and clear again thanking u for ur kind response ....regards bajjal
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Time history of turbulence intensity at one point trantoan2008 FLUENT 0 October 17, 2011 08:54
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Effects of turbulence on freesurface sek OpenFOAM Running, Solving & CFD 4 March 22, 2008 21:48
