Project Help--Discontinuous Galerkin (FV) for Compressible Euler Eqs |
March 25, 2013, 19:43 |
Megan
Rep Power: 13 |
Hello, I am sort of new to this forum so my apologies in advance if I happen to violate some unspoken cfd forum rule...
I am currently working on a project for a class in which I must write a code to solve the 2-D Euler equations on an unstructured grid using an explicit 2-stage Runge-Kutta temporal discretization method, and a flux vector splitting scheme of my choosing (I am thinking van Leer for simplicity's sake). I think currently most of my questions are going from conceptual to application (ie discretizing the problem in a code) and I was hoping to get some help from the ether on such matters. For starters does anyone have a link to a site or paper or reliable source that explicitly states the flux vectors (+ and -) F and E? Or rather does anyone have the vector forms for these I would like to verify what I am doing it correctly for debugging purposes. Secondly, when going from P_{0} to P_{1} DG how is the Runge-Kutta time stepping scheme modified (ie addition eqations, flux calculations change etc) currently I have the formula as U_{0}=U^{n} - \frac{1}{2} \DeltaT R(U^{n}) 1st stage U_{n+1}=U^{n} - \DeltaT R(U^{n}_{0} 2nd stage where U = [\rho,\rhou,\rhov,\rhoE]^{T} Thanks for any help or direction that is offered!! |
September 15, 2016, 03:32 |
Hi Spacegirl1923 ,
I have formulated field equations, based on an ideal compressible aether model: http://www.cfd-online.com/Forums/ele...-openfoam.html Might be interesting to you. |
discontinous galerkin, euler equations, finite volume |
Weak and strong form of Discontinuous Galerkin method | aferrero | Main CFD Forum | 0 | June 14, 2012 11:49 |
Discontinuous Galerkin method fo 1D Navier Stokes | SKLee | Main CFD Forum | 0 | October 27, 2011 13:45 |
Runge Kutta Discontinuous Galerkin procedure? | Ameya J | Main CFD Forum | 6 | July 29, 2011 05:56 |
Discontinuous Galerkin schemes -- fortran source code | diedro | Main CFD Forum | 3 | March 12, 2011 10:20 |
Discontinuous Galerkin finite element method | Tony | Main CFD Forum | 0 | May 27, 2003 18:48 |
