Motion of sphere freely suspended in channel flow
Old   August 12, 1999, 07:39
Default Motion of sphere freely suspended in channel flow
faithkim
I am using CFX I want to simulate the motion of sphere(structure). 2D: The motion of cylinder in channel flow 3D: The motion of sphere in tube flow
But I don't know what i have to do.
Welcome any advice and any examples(very good)
Thanks a lot
Old   August 12, 1999, 10:42
Default Re: Motion of sphere freely suspended in channel flow
Patrick Godon
Hi there,
I can give you some references for the theoretical point of view:
Concerning the motion of the sphere, you might want to have a look at the paper
Maxey and Riley, 1983, Physics of Fluids, vol.26, page 883, "Equations of motion for a small rigid sphere in a nonuniform flow".
This should give you some introduction and details on the problem in general (you don't need to look at all the equations, just the physical processes).
You can also find some good textbook on a cylinder moving in a fluid, with the fameous Von Karman vortex street, etc.. for example: the book of Schischling (not sure about the spelling) on the theory of the boundary layer. This should also give you a first approach to the problem.
What symmetry are you looking at? if any?
Then you will have to decide on boundary conditions and initial conditions (if the problem is time dependent). This depends on exactly how you specify your problem, but I guess you will have mainly an inflow and outflow, together with some (moving) wall boundary condition (since you probably want to move the flow/channel, rather than the cylinder/sphere).
PG
Rotating sphere in a turbulent flow kpsl OpenFOAM Pre-Processing 0 November 27, 2010 08:50
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 07:32
Open channel flow Mehdi Moayeri FLUENT 0 August 26, 2008 10:55
open channel flow sachin jadhav FLUENT 0 April 9, 2008 15:53
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
