Lattice Boltzmann .. Moving irregular wall
Old   June 16, 2006, 14:14
Default Lattice Boltzmann .. Moving irregular wall
Ahmad Al-Zoubi
Dear all
My question is about the boundary conditions in LBM. I want to simulate flow through bearings. The geometry consist of two parallel walls. It is easy !!!!! ... BUT the walls are not smooth and they are mooving with constant velocities.
My question is how to deal with moving irregular boundaries?.
Thanks alot
Ahmad
Old   June 29, 2006, 09:54
Default Re: Lattice Boltzmann .. Moving irregular wall
Raul
Hi
Irregular BC is not a problem. If you are not interesting in high order of accuracy, just deal with (full) Bounce Back with 1 order of accuracy. That's all. Otherwise, use half bounce back with 2nd order of accuracy but more computations, as you should know at this point. Regarding moving boundaries, I think, as the first though, you have to use an equation that deal with such "movement". If you are refering to irregular movement, that "equation" should deal with that. Good luck
Cheers Raul
Old   June 29, 2006, 12:14
Ahmad Al-Zoubi
Thank you very much for your answer.
I think you didn't understand the question very well. To apply Bounce back for irregular boundaries is very easy task as you have said. The question is what happen if this boundary is moving... This means that the mesh (grid) will change with time. The problem is if one move it one lattice unit length every lattice time step, this will fix the velocity of the boundary to be 1 and this violate the incompressiblity (u<0.3).
Thank you agian.
Ahmad
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
moving wall on poppet valve?? anwar FLUENT 0 January 19, 2007 11:39
moving wall BC problem Sourabh Main CFD Forum 1 August 8, 2006 07:47
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 12:42
