June 19, 2006, 23:34 |
unsteady using SIMPLE algorithm
I try to simulate the flow over a plunge NACA0012 using the SIMPLE algorithm and rigid moving grid with the airfoil. but it is hard to converge and the Cl & Cd are much larger than experiment data. who has experience about this problem?
June 21, 2006, 02:01 |
Re: unsteady using SIMPLE algorithm
ok as u said convergence problems it could be worked out with the underrelaxtion factors (decreasing them too much can lead large computational time) but did u check all other conditions whether given properly even if mesh is too much refine this convergence problems come into field so try better with coarse grid to start off,u havent mentioned the flow solver u used.
Is it ur problem is unsteady with moving mesh can u define ur problem more clearly . if Cl ,Cd are monitoring parameters than they would finally settle down to correct values intially though they may fluctuate . |
June 21, 2006, 12:04 |
Have you validate your code!
June 24, 2006, 03:43 |
Thanks! I use a in-house code that was validate many times before calculation this case.
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
SIMPLE algorithm confusion | lost.identity | Main CFD Forum | 1 | October 7, 2010 11:48 |
The SIMPLE Algorithm | Hooman | Main CFD Forum | 3 | June 8, 2010 22:55 |
SIMPLE algorithm for collocated storage | alex | Main CFD Forum | 4 | April 8, 2008 23:48 |
outflow boudary condition in SIMPLE algorithm | dallybird | Main CFD Forum | 0 | March 6, 2003 11:55 |
