Exact solution - Euler equations
Old   May 2, 2013, 14:07
Default Exact solution - Euler equations
Jakub
jakubstary is on a distinguished road
I work on numerical solution of Euler equations in 1D. I implemented some numerical schemes and now I need compare their accuracy due to the exact solution. But I don't know how to compute it. For Burger's equation I compute exact solution with method of characteristics, but I don't know how to implement it for Euler equations or whether it is possible. Can anyone get me some tip how to compute exact solution of Euler equations? Many thanks. Jakub
jakubstary is offline   Reply With Quote
Old   May 2, 2013, 14:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
you can find many references for the Sod problem ...
FMDenaro is offline   Reply With Quote
Old   May 3, 2013, 00:29
Ravindra Shende
Ravindra Shende is on a distinguished road
Check out this paper: ANALYTICAL SOLUTIONS FOR THE UNSTEADY COMPRESSIBLE FLOW EQUATIONS SERVING AS TEST CASES FOR THE VERIFICATION OF NUMERICAL SCHEMES - Tsangaris and Pappou
Also look in the text 'Computational Gasdynamics' by Culbert Laney.
Ravindra Shende is offline   Reply With Quote
Old   May 3, 2013, 02:55
Fabian82 is on a distinguished road
Check the book on Riemann solvers by Toro, there you'll find many shock tube problems together with the behavior of many different discretizations.
A good starting point may also be:
http://www-troja.fjfi.cvut.cz/~liska...re8/index.html
Moreover, you could setup sound waves in the linear regime.
Going to two or three dimensions, simulating flow instabilities (e.g. shear, convection, rayleigh-taylor) and comparing the growth rates to the theoretical estimates can give much insight into a numerical discretization. Besides that, computing (stationary) vortices are also a good code validation.
Fabian82 is offline   Reply With Quote
Old   May 3, 2013, 10:00
Default Solved
Jakub
Thanks all. It was very helpful for me. I have one more question about solving Euler equations. Please can you get me a good tip again?
I use Euler method, Runge-Kutta 2nd order method and RK 4th order method for time discretization. I think that RK4 method should be the best and RK2 method better than Euler, but in every cases I get the best accuracy with Euler and worst with RK4. Don't you have any idea where would be a mistake in my implementation?
Thanks.
Jakub
Old   May 3, 2013, 14:49
cfdnewbie
cfdnewbie is on a distinguished road
Did you test your implementation of RK2 and 4 for a system of ODEs? It sounds to me like there must be a bug in your implementation?
cfdnewbie is offline   Reply With Quote
Old   May 4, 2013, 14:40
Jakub
I implemented Euler and RK2 on ODEs, but I get same bad results. In first few times RK2 is better than Euler, but after some time not. I enclosed figure with my results. In figure is Euler, RK2, Matlab ode 23 and exact solution. I must have bug in implementation or bug is in book (Finite Volume Method for Hyperbolic Problems - LeVeque - equations (10.18)) which I use.
Here is my code of RK2:
function dy = rigid(t,y)
    dy = 3*exp(-4*t)-2*y;
end
for i=1:length(t)-1
   k1=rigid(t(i),rk2(i)); %derivate
   ystar1(i)=rk2(i)+h*k1; %y*
   k2=rigid(t(i),ystar1(i)); %derivate
   ystar2(i)=ystar1(i)+h*k2; %y**
   rk2(i+1)=0.5*(rk2(i)+ystar2(i)); %result = 1/2*(y + y**)
end
Many thanks!
Jakub
Old   May 6, 2013, 06:47
Jakub
Please, has anybody any idea for my problem with Runge Kutta? Thanks.
Jakub
Old   May 6, 2013, 08:02
I guess the second evaluation of 'rigid' should not be at time t(i). The algorithm in LeVeque is defined for problems without an explicit time dependence. You should look up the butcher tableau for this time marching scheme to find out the correct time for the second evaluation. I guess, it's just t(i) + h but look it up in order to be certain!
Old   May 6, 2013, 18:14
Jakub
Yes, t(i) + h was the problem. Thanks Fabian82 .
So if I apply now Runge Kutta 2nd order method on Euler equations or on other system of hyperbolic partial differential equations I get this:
U* = U(n) + dt*G(U(n)) - first step
U** = U* + dt*G(U*(n+1)) - second step
and result is:
U(n+1) = 1/2*(U(n) + U**).
But how can I compute U** when I don't know U*(n+1) in the second step?
Many thanks to all. Jakub.
euler equations, exact solutution
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Delta form of Heat, Euler and NS equations RameshK Main CFD Forum 3 May 30, 2012 10:41
Exact solution of N-S eq. in Kim and Moin's paper Kyounghwa Main CFD Forum 5 January 23, 2012 09:36
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Euler equations & expansion shocks technophobe Main CFD Forum 5 April 28, 2009 15:11
