matching arbitrary meshes
Old   July 17, 2006, 11:40
Default matching arbitrary meshes
oulebsir redouane
hello,
I am trying to match a flat mesh another one wich is curved, so the verticies don'y match.
could you tell me the easiest way to achive this purpous. Or where can I find the instructions which would help me.
Old   July 17, 2006, 15:45
Default Re: matching arbitrary meshes
RW
If one of the meshes is regular, the second mesh can be joined to it using an eliptical generation technique. In the eliptical generation, you specify the locations of the vertices of the curved mesh that are adjacent to the vertices of the regular mesh.
Let's say that the regular mesh is to the left of the curved mesh. Then, the right edge of the regular mesh becomes the left boundary of the curved, eliptically-generated mesh. The other boundaries enclosing the eliptic mesh must also be specified. The locations of the interior points are smoothly distributed between the boundaries by solving an eliptic equation over them, usually using a relaxation technique.
See:
"Automatic Numerical Generation of Body-Fitted Curvilinear Coordinate System for Field Containing Any Number of Arbitrary Two-Dimensional Bodies"; Joe F. Thompson, Frank C. Thames and C. Wayne Mastin; Journal of Computational Physics; Volume 15, pages 299-319; 1974
Rich
Old   July 17, 2006, 17:44
RW
I just worked out the answer and tested it. Let me know if you'd like to see it.
Thanks for your help.
Rich
Old   July 17, 2006, 17:49
RW
Oops, sorry. Ignore that last message.
Old   July 18, 2006, 04:04
oulebsir redouane
hi,
thank you for your interest, I will try to use your method, and I will let you know the progress.
Old   July 18, 2006, 04:06
oulebsir redouane
obviously i would like to see see the answer.
thank you.
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 23, 2012 23:41
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
Arbitrary Sliding Meshes Anna Siemens 0 September 1, 2002 06:02
Arbitrary Matching & Partial Boundaries George Siemens 6 July 10, 2001 09:58
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
