Euler & N-S EQUATIONS from Boltzmann EQUATION
Old   August 25, 1999, 00:37
Default Euler & N-S EQUATIONS from Boltzmann EQUATION
Yogesh Talekar
Gurus,
Can anybody tell me some literature where derivation of NAvier-Stokes and Euler equations FROM BOLTZMANN EQUATION of statstical kinematics is given.
I checked in few books but the methos they talk of are very difficult to understand.
Thank You
Yogesh
Old   August 25, 1999, 07:43
Default Re: Euler & N-S EQUATIONS from Boltzmann EQUATION
Jim Park
For a very readable development, try
Present, R. D., "Kinetic Theory of Gases," McGraw-Hill, 1958.
Also,
Mayer & Mayer, "Statistical Mechanics," Wiley, 1940.
Some of you newer fellows might recommend some newer books.
Old   August 29, 1999, 12:38
An
Hello Mr Talekar:
Exa Corporation in the US has developed a new class of CFD solver based on kinetic theory and statistical physics (lattice Boltzmann). The macroscopic Navier-Stokes equations are recovered from Exa's digital physics algorithm. There is more technology information at the Exa web site: http://www.exa.com
An
Old   August 29, 1999, 23:35
Andrzej Matuszkiewicz
Do they have derivation of NS eqs or references to it at their web page?
Andrzej
Old   August 30, 1999, 00:22
Yogesh Talekar
No there is no such reference to the derivations on the web-page. But still I am quite a lot in dark about the derivation.
Somebody should help me!
Old   August 30, 1999, 09:31
Praveen Chandrashekar
Hello!
Here are some published papers on kinetic schemes for Euler Equations, which also show the connection between the Boltzman equation and the Euler equations.
1. SM DESHPANDE, "Kinetic theory based new upwind methods for inviscid compressible flows", AIAA Paper, 86-0275, 1986
2. JC MANDAL & SM DESPHANDE, "Kinetic Flux Vector Splitting for the Euler Equations", Computers and Fluids, vol.23, pp. 447-478, 1994 (You should be able to get this easily)
I found the following book to be very good. It contains a section on kinetic schemes. You will find more references in this book.
GODLEWSKI and RAVIART: Numerical Approximations to Hyperbolic Systems of Conservation Laws, Springer.
Hope this helps.
Old   August 30, 1999, 15:50
Mayank Tyagi
Hi Yogesh..
There is ICASE report 99-21 (www.icase.edu) by Qian et al titled "On higher order dynamics in lattice-based models using Chapman-Ensog method".... You can download that...
Y.H. Qian's Phd dissertation is " Lattice gas and lattice kinetic theory applied to the Navier-Stokes equation"
Hopefully this will give you a start...
regards
Mayank Tyagi
Old   August 31, 1999, 05:31
Default Thankx a lot
Yogesh Talekar
Respected "gurus"
Thank u very much for you help and guidance.
But still something more is needed
Yogesh
Old   August 31, 1999, 05:35
Yogesh Talekar
Dear Praveen
Thank you very much for the suggestions. I will certainly try to go through the litureature
Thank you once again
YOGESH
Old   September 1, 1999, 12:11
Dave Higbie
Yogesh,
Here are some more references you can try:
"The Mathematical Theory of Non-Uniform Gases", S. Chapman, T.G. Cowling, Cambridge University Press
"Statistical Mechanics", K. Huang, John Wiley & Sons., Inc. Chapters 3-6
On Exa's website there is a paper called: "Digital Physics Approach to Computational Fluid Dynamics: Some Basic Theoretical Features", Chen, Teixeira and Molvig. Journal of Modern Physics C., Vol. 8 (1997) pg. 675
a postscript file link to the above paper can be found at
http://www.exa.com/powerflow/papersdir.html
Hope this helps.
Dave
Old   September 13, 1999, 09:00
Default fluent bfc 2 triangular mesh
  #11
alfred almer
I would like to convert a bfc-mesh A created by fluent into a mesh B . The format of the mesh B should be similar to the one ,i would use in povray to render the object depicted by A . That is, find triangles,that make up the surface of the object,that has been rendered into mesh A . UNfortunately,i donīt have access to a copy of the fluent software. Is there a way to to do this conversion by hand ?
Mesh A looks like #!fluent.1
2 Created by : ICEM CFD/CAE FLUENT Interface Vers. 3.3.2 #
1 Title FLUENT Grid File /* CONFIGURATION = tbif */ #
6 Grid Type
2 1 3 14 98 51 #
9 BFC Grid -1.214401E-08 -9.703458E-06 -1.838437E-05 -2.586320E-05 -3.196537E-05 -3.652791E-05 -3.939371E-05 -4.040466E-05 -3.939997E-05 -3.626388E-05 .........
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
Delta form of Heat, Euler and NS equations RameshK Main CFD Forum 3 May 30, 2012 10:41
Jacobian of 1D Euler Equation of Gas Dynamics Simplicity. Main CFD Forum 3 September 6, 2011 14:12
Euler ~Navier Stokes equation Khan Main CFD Forum 1 September 9, 2006 03:26
Linearized Euler Equation vasanth Main CFD Forum 0 May 30, 2004 15:25
