how to calculate load carrying capacity of a hydrodynamic journal bearing
Like Tree1Likes
  • 1 Post By Dinesh_Dhande
Old   June 26, 2013, 10:16
Smile how to calculate load carrying capacity of a hydrodynamic journal bearing
Dinesh
Dinesh_Dhande is on a distinguished road
Dear friends,
i m simulating hydrodynamic journal bearing using gambit and fluent. i hav obtained static pressure distribution in the bearing. how to calculate load capacity using report option in fluent?
thanks in advance.
sozen likes this.
Dinesh_Dhande is offline   Reply With Quote
Old   May 4, 2015, 17:00
sozen is on a distinguished road
I've been searching for the answer. Did you get it? Thanks!
sozen is offline   Reply With Quote
Old   May 6, 2015, 03:19
Troy Snyder
tas38 is on a distinguished road
Is your rotor a selectable wall zone in the force report? If so, you can simply
select it and there your go. Depending upon how the bearing was loaded, i.e. via
applied force or applied eccentricity, and in what direction, the output forces may be
either in the fixed frame (fx,fy) or the rotating frame (fr,ft).
tas38 is offline   Reply With Quote
solving finite journal bearing problem by finite difference Atit Koonsrisuk Main CFD Forum 6 March 29, 2015 08:09
Journal Bearing hunny_winky STAR-CCM+ 0 April 9, 2010 17:26
How to simulate a dynamically loaded journal bearing with Fluent? okiro FLUENT 0 April 7, 2010 21:16
how to draw journal bearing fluid using gambit?? zidane FLUENT 0 March 8, 2009 12:40
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
