droplet separation off a particle in turbulent stream
Old   August 22, 2013, 13:40
Default droplet separation off a particle in turbulent stream
Pratik Pednekar
anonymous_89 is on a distinguished road
I am looking to develop the following system in a different platform, but I could use a little help from anyone with a CFD background and good understanding of particulate flow. I would very much appreciate the help in making sense of this.
The following is the system I am looking at.
A droplet resides on a particle. The size of the particle is 100 microns and the droplet is around 1-10 microns. The system is in a plug flow reactor with low slip velocity ( U_particle - U_gas is not very high). The Reynolds number of the gas in the reactor is very high (10^5) (calculated using gas velocity and diameter of the reactor) while the particle Reynolds number is very low (10^-2) (calculated using slip velocity and diameter of particle).
I would like to know the shear rate on the particle, so as to see whether the gas flow can separate the droplet sitting on it by overcoming the adhesion force (droplet contact angle is very high). (Drag force on the droplet is not sufficient alone)
My question is, would it be correct, due to the smaller slip velocity and small Particle Reynolds number, to model the flow around the particle as stokes flow? Can i make any assumptions to simplify this problem in the Navier Stokes eqn.
If I know the boundary layer thickness over the particle, i could calculate the shear rate on the particle. how can i go about this?
Thanks
anonymous_89
anonymous_89 is offline   Reply With Quote
lift force on particle, particulate flow, shear rate on sphere, turbulent stream
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
cyclones and particle separation MachZero Main CFD Forum 0 July 7, 2013 22:20
Airfoil turbulent separation Seroga Main CFD Forum 0 October 23, 2008 02:02
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
separation and stream function co2 FLUENT 0 December 27, 2003 18:18
