August 22, 2013, 14:57 |
vortex shedding frequency
Ali
Rep Power: 13 |
Hi all
Will somebody help me that what is the most simple way to calculate the vortex shedding frequency or the Strouhal number for flow past a circular cylinder?(2D) |
August 22, 2013, 15:12 |
Rep Power: 18 |
Compute the lift, store the time history of the lift, and then do an FFT of the lift history. Or, simply measure the period of the cycle from the lift history and invert.
August 22, 2013, 15:35 |
#4 | |
cfdnewbie
Rep Power: 20 |
That's absolutely correct, just make sure that you take enough cycles into account before doing FFT, excluding any initial transients (e.g. when starting from potential or constant flow) |
August 30, 2013, 20:37 |
#5 | |
Rep Power: 15 |
Just record the time history of the vertical velocity on a fix point in the wake, it's enoughand perform an FFT as Agd said. |
August 30, 2013, 22:30 |
Rep Power: 18 |
While the time-averaged lift will be zero, the instantaneous lift force should oscillate at the shedding frequency. Computing the lift is extra effort, but it can provide additional information on the quality of the solver - for example by checking that the time-averaged lift actually does equal zero.
August 31, 2013, 07:15 |
#7 | |
Rep Power: 15 |
The lift of a symmetric body is null. You can not lift a sphere or cylinder with a circular base. For the drag force your are right |
August 31, 2013, 09:15 |
Rep Power: 18 |
Um, no. See for example
http://www.dtic.mil/dtic/tr/fulltext/u2/a273243.pdf The instantaneous lift force on the cylinder is not zero. Th average lift force is zero. The average drag will not be zero, and the instantaneous drag will oscillate at twice the Strouhal frequency. |
vortex shedding frequency | naveen | OpenFOAM | 23 | May 17, 2016 08:12 |
fluent gets wrong airfoil vortex shedding frequency | eaglexyb | FLUENT | 0 | July 19, 2012 10:39 |
frequency of vortex shedding | HaKu | Main CFD Forum | 3 | March 18, 2011 00:00 |
time step and vortex shedding frequency | kevin | Main CFD Forum | 16 | November 19, 2009 06:00 |
Vortex shedding frequency stays unaltered | Nelson | Main CFD Forum | 3 | March 5, 2009 10:04 |
