pressure development
Old   August 31, 2013, 13:29
Default pressure development
prom is on a distinguished road
Dear friends,
I was trying to simulate non-reacting flow characteristics in a simple can type gas turbine combustion chamber. The pressure contour showed that the pressure increased from inlet face to exit face. My question is what is the reason to increase in pressure. As the velocity increases, the pressure should decreases no? Please correct me if I am wrong.
Thanks in advance.
Prom
prom is offline   Reply With Quote
Old   August 31, 2013, 16:06
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by prom View Post
Dear friends,
Thanks in advance.
Prom
Please, more details should be provided... compressible/incompressible model, geometry, steady/unsteady solver, etc.
You made an assumption based on the Bernouilli relation but that applies for isoentropic, incompressible flows. Are you solving viscous flows?
FMDenaro is offline   Reply With Quote
Old   September 1, 2013, 03:25
It is compressible model, the geometry is simple can type combustor solved for steady state, isothermal process. Air is used as fluid.
Old   September 1, 2013, 17:58
ok, could you post the figures (iso-contour) of pressure, density and velocity?
Old   September 2, 2013, 00:56
https://docs.google.com/file/d/0B9tq...it?usp=sharing
follow this link to see pressure contour
Old   September 2, 2013, 03:05
michujo is on a distinguished road
Hi. Is that the static pressure? I think it makes sense since the flow is decelerated along the combustor. Flow is injected from a nozzle at very high speed and small section area. As the gas flows along a wider section it is decelerated (to conserve total mass flow rate) and therefore its static pressure is increased.
Did you try plotting the total pressure (static + dynamic). I guess you'll then obtain a decreasing profile along the combustor.
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   September 2, 2013, 03:51
1) what pressure you are plotting? I see Pascal in the scale but I also see negative values, therefore what is plotted is not p= rho*R*T
2) your model is compressible, therefore without density and velocity the pressure plot alone does not make sense
3) are you using also some turbulence modelling? because for compressible model it enters into the pressure
Old   September 2, 2013, 10:23
yes I used k-epsilon model
Old   September 2, 2013, 10:43
Yes it is static pressure plot... I am pretty convinced by Mr. Michujo's explanation. thank you sir. And I am new to CFX, I don't know how to plot the total pressure. BUt I'll give it a try...
Old   September 4, 2013, 01:15
Dear Filippo Maria Denaro,
Is it wrong if negative pressure comes. please explain it. kindly elaborate the concept of it.
thank you...
Old   September 4, 2013, 03:50
If you plot the thermodinamic pressure rho*R*T it must be always positive, if you plot the dynamic pressure rho*V^2 it must be positive, too.
Therefore, or you are plotting a scaled pressure or your results are wrong.
In any case your plots say nothing if are not completed by other variables
Old   September 4, 2013, 09:56
Dear Filippo,
In CFX post I used pressure which we get by clicking on pressure in contour ploting. I dont have knowledge whether it is thermodynamic or dynamic pressure. But if I plot total pressure, then also I get negative pressure. I have very little knowledge in this. Plz tell me where it has gone wrong. The total pressure is in this link: https://docs.google.com/file/d/0B9tq...it?usp=sharing
Thank you
Old   September 4, 2013, 10:07
Dear Filippo,
Thank you
Sorry to say that using a CFD code is not as same as using a Play Station... You must be aware of the physics of the problem, having knowledge of fluid dynamics, numerical analysis and eventually have a look to the manual of CFX
Old   September 4, 2013, 10:19
I am very sorry for my stupid questions sir. I am a beginner. Thanks for all your replies.
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 3 September 24, 2018 16:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
Difference between pressure, absolute pressure and Total Pressure shaswat CFX 1 September 6, 2012 06:12
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
