CGNS help~~
Old   September 1, 2013, 04:12
Thumbs up CGNS help~~
Shengyi Wang
gmwsy is on a distinguished road
Dear every master,
I need to get the details of some boundary conditions(e.g. the wall temperature of an 'isothermal wall' type bc) from CGNS file. However, the MLL library seems not to provide any function to get this information.
I guess, maybe, a combination usage of the 'cg_goto' and 'data_array_read' functions has to be implemented but have not suceeded for now.
Would any body like to give a hand on this problem? Thanks a lot.
Shengyi
gmwsy is offline   Reply With Quote
Old   September 3, 2013, 09:57
duri
duri is on a distinguished road
Use adfviewer or cgnsviewer to read boundary condition information. cg_goto and cg_array_read would work easily only if the datatype, size and location are know in advance. Otherwise it would be little difficult.
duri is offline   Reply With Quote
Old   September 4, 2013, 10:52
Arrow thanks
Shengyi Wang
Dear duri,
thanks a lot for your help. ADFviewer is indeed a powerful tool to view cgns data. However, for my instance, I need to write a code to extract the boundary condition data as an input of a CFD solver. I have tried the cg_goto way, and it could work assuming that there is only one dataset_t node under its parent node bc_t.
I have another problem with getting the latest cgns libraries for windows. would you kindly give a hand with that?
Best wishes,
Shengyi
Old   September 5, 2013, 04:52
duri
I recently compiled cgns file for windows using visual studio. It is little tricky but I could help you.
cgns bc
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[Gmsh] Cgns support for gmsh robyTKD OpenFOAM Meshing & Mesh Conversion 1 July 13, 2016 11:27
parallel support with CGNS format not yet implemented kirkrich SU2 3 January 18, 2013 15:39
Cgns b91 Main CFD Forum 1 June 20, 2012 06:07
develop CFD code based on CGNS vito Main CFD Forum 3 May 3, 2005 11:45
