L0, L1, L2 ,Linf error norms
Like Tree4Likes
  • 1 Post By Vino
  • 3 Post By duri
Old   September 10, 2013, 14:54
Post L0, L1, L2 ,Linf error norms
Vino
Vino is on a distinguished road
1)can some one suggest me how to calculate the L0, L1, L2 ,Linf error norms for a 2d case (eg:100X100 grids)?
2) To calculate norms, what are all needed for a steady/unsteady problem?
3) For example, i am solving a incompressible flow over cylinder problem for steady and unsteady, how to generate above said error norms for this problem?
Thanks in advance.!!!
aerosayan likes this.
Vino is offline   Reply With Quote
Old   September 11, 2013, 14:05
duri
duri is on a distinguished road
If you want to calculate Ln (nth norm) of a vector, then formula is nth root of( a1^n + a2^n ... + ap^n). Where p is the vector size.
In CFD, residuals are estimated as average over the grid points. L2 norm is equivalent to RMS. Eg., to calculate T residual (temperature) then it is sqrt((T1^2 + T2^2 .. + Tn^2)/n). where n is cell or node count and T1 is (new T - old T) at cell 1.
L1 is equivalent to average of abs(T) residual on the mesh. Linf is the max T residual on the mesh. L0 is number of non-zero elements, I wonder why do you need this norm in residual.
duri is offline   Reply With Quote
Old   September 12, 2013, 08:10
Vino
I have lot of confusion in this.... yes. Residual is to check the convergence of the steady state problem (What u have told based on T is a L2 norm???) . Can we use any other norms in residual calculation? In case of unsteady problem, how to check the error or how to check the convergence ? please clarify
Thanks.
Old   September 12, 2013, 08:23
Default Norm
ImanFarahbakhsh
ImanFarahbakhsh is on a distinguished road
I wrote it in Latex syntax
error is a vector with m components then
norm of order nth (L_n) can be defined as
L_n(error)=(\Sigma_i=1^m{{e_i}^n})^{1/n}
Also L_0 is nonsense???
ImanFarahbakhsh is offline   Reply With Quote
Old   September 12, 2013, 09:22
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
pointwise o averaged Holder norms? You can see the topi in a book of numerical analysis, also the LeVeque book is good
FMDenaro is offline   Reply With Quote
Old   September 12, 2013, 10:13
Vino
I will check in Leveque book... thanks for your clarification....
