How to export gambit model to ICEM
Old   October 28, 2006, 03:44
Default How to export gambit model to ICEM
Nirupama
Hi, This is Nirupama. I want to export a 3D model from gambit to ICEM.I have generated a volume for the model. Should i define the boundary conditions in Gambit and then import the model in ICEM. What is the extension to be used while exporting the model to ICEM.
Thanks and Regards Nirupama
Old   October 28, 2006, 13:06
Default Re: How to export gambit model to ICEM
myron
If you are talking about a geometry - you will want to export the ACIS file (.acs). If you've already generated the mesh, ICEM can simply load the .msh or .cas file.
[ICEM] Export half of the model from ICEM to CFX enghamed ANSYS Meshing & Geometry 3 July 30, 2010 10:23
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 14:21
Gambit and parametrized model generation MN FLUENT 0 October 8, 2003 20:01
