contact angle between liquids
Like Tree4Likes
  • 1 Post By manxu
  • 2 Post By triple_r
  • 1 Post By manxu
Old   October 16, 2013, 07:45
Question contact angle between liquids
Rams Manu
manxu is on a distinguished road
I would like to know how the contact angle at the interface of two liquids (for ex : a water droplet on an oil surface) is determined. I tried a lot to find out any theories to give a quantitative model or formulae to find out the contact angle at the interface (as shown in fig. which I found in google, but couldn't find out the source of it !) but none was there. Can anybody pls explain or point out to me the way to obtain a contact angle for this problem ?
Moreover, when the oil droplet relatively moves over the water surface, do we still have the problem of moving contact lines as in the case of a droplet on a wall (with no slip) ? Is the shikhmurzaev model applicable to this case?
Regards,
Manxu.
Nartasan likes this.
manxu is offline   Reply With Quote
Old   October 16, 2013, 10:30
Reza
triple_r is on a distinguished road
Try this paper:
Chang-You Lin, Michael Widom, Robert F. Sekerka, "Mean-field Density Functional Theory of a Three-Phase Contact Line", Physical Review E, 85(1), 2012.
http://pre.aps.org/abstract/PRE/v85/i1/e011120
manxu and Nartasan like this.
triple_r is offline   Reply With Quote
Old   October 16, 2013, 12:38
Rams Manu
Thank you for your reply.
That was really worth a read.
Although implementing them might be difficult, by any chance, do you know if they are being taken care of in fluent or openFOAM's VOF or Euler-Lagrange model ?
Old   October 16, 2013, 12:51
Reza
Hmmmmm, the force balance is being satisfied in those solvers, so I'm guessing at least the equilibrium state equations should be satisfied (if they ask for all possible pair surface energy values). Not sure about the dynamic case though.
Old   October 17, 2013, 06:22
Rams Manu
The Navier -Stokes equations are incompatible in a no-slip boundary condition and moving contact line (along the solid boundary).
So, as in my case, are the Navier Stokes equation compatible along the liquid-liquid-fluid (ie., oil-water-air) contact line ? If so, there shouldn't be a problem with the dynamic contact angle in my case if I run it in fluent or CFX right ?
Old   October 18, 2013, 10:15
Reza
It should be, but the thing that worries me is that the interfaces are not sharp. For a diffuse interface, such as the ones you get from VoF, there might be some issues.
contact angle, contact line, oil-water
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
InterFoam contact angle JoaoMiranda OpenFOAM Running, Solving & CFD 7 October 20, 2016 06:27
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
