Searchintg Exp. Data of 2D compressible Flow in static stall
Old   September 6, 1999, 21:50
Default Searchintg Exp. Data of 2D compressible Flow in static stall
C-M.Yang
Hi everyone! I'm finding experimental date of static stall problem of 2D compressible flow. As you know, in the airfoil problem, as the angle of attack increases, the Lift coefficient also increaes in a certain range. But when angle exceed a critical point, separation occurs to make Cl drop adruptly, which is called "STALL". The book of "Theory of Wing Section" by ABBOTT is the well-known reference for incompressible flow. I want the data for compressible flow. Especially I need the following cases.(Of cource, other cases are welcome)
M=0.6 Re=4.5x10^6 NACA0012 airfoil
thanks.
Old   September 8, 1999, 10:47
Default Re: Searchintg Exp. Data of 2D compressible Flow in static stall
Joerg Weidenfeller
Hi! Check the following web site:
http://www.maths.adelaide.edu.au/app...usk/aero/foil/
For NACA0012 and others there are CL/CD coefficients for Reynoldsnumber from 1.6*10**5 to 50*10**5.
Joerg
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 13:16
3-D Compressible Flow Boundary Conditions Tyler FLUENT 4 February 5, 2009 19:58
Compressible Flow Modelling? yeo FLUENT 4 March 7, 2003 07:08
Exp. data for transonic flow J. Held Main CFD Forum 4 April 1, 1999 22:21
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
