December 18, 2013, 07:34 |
velocity vectors
Rep Power: 12 |
Hi
I have simulated 2-D flow applying velocity inlet and pressure outlet boundary conditions.Later I applied periodic boundary conditions at inlet making the outlet conditions as shadow zone.After convergence, I see the velocity vectors coming out of the outlet zone.Why is this happening? |
December 18, 2013, 12:03 |
Alex
Rep Power: 47 |
Why should it not happen?
December 20, 2013, 01:21 |
Rep Power: 12 |
Thank you for the question that made me to think.I was initially in an impression that all the vectors will be represented in the closed domain.I came to that they need not be .
I have another problem now. Iam simulating the flow over solids(squares).For this, I created a domain(big rectangle) with solids squares inside.I gave velocity inlet boundary condition at the entrance and pressure outlet at the exit.I have meshed it and transferred to fluent.I have applied periodic boundary conditions at the inlet making the outlet shadow. I have run the case for different grids with convergence criterion of 10-6.As I refine the grid the the curve goes flatter.Why is this happening? Which value is to be taken for further analysis?please find attached a pic of the grid independent study result. |
December 20, 2013, 04:42 |
Alex
Rep Power: 47 |
I have no idea which values you put into this figure, so it is impossible to comment on the results.
And please, attach figures in a file format that everybody can read without much effort, something like .png or .jpg would be nice. |
December 20, 2013, 09:31 |
Grid independent study
Rep Power: 12 |
Thanks for the response.
Please find the following files attached 1.Model with boundary conditions with out mesh 2.Model after mesh generation a.After mesh generation ,mesh is transferred to FLUENT. b.Periodic boundary conditions are applied at inlet making the outlet shadow.Convergence criterion is kept at 10-6. c.After convergence,a vertical rake exactly at the center of the model is created .Velocity magnitude along the rake is exported to excel sheet. Then the mesh is refined and send to FLUENT and steps (b) and (c) are repeated.I have done this with many(6) times.The velocity magnitude curves go flatter with refinement. If I change my convergence criterion to 10-7,all curves coincide how coarser or how finer I change my grid. What convergence should I take? Which curve value should I take for my study? I am confused.Why is this happening? Sorry,I could'nt send the pics in the format which you mentioned. Thank you |
December 20, 2013, 12:01 |
Alex
Rep Power: 47 |
If the curves change as you lower the convergence criteria, the solution can not be considered converged.
Instead of comparing the errors introduced by coarse meshes, you compare the errors from insufficient iterations. My tip for steady-state simulations in an academic context: Run the case until the residuals level out. Then you can compare the errors caused by the discretization or any other influence you want to investigate. |
problem with velocity magnitude and vectors | Hayder Mohammed | FLUENT | 0 | August 7, 2013 03:08 |
I need help about velocity vectors direction in cylinder modeling!!! | aminepoxnet | FLUENT | 0 | March 17, 2013 17:41 |
Inaccurate velocity vectors | Arun Prasad | FLUENT | 4 | August 2, 2012 00:43 |
how to display a clear vectors of velocity | clauss | FLUENT | 1 | October 24, 2006 07:30 |
Velocity vectors clipping | Vidya | FLUENT | 0 | July 31, 2006 21:53 |
