Elliptic-parabolic/Hyperbolic-parabolic N.S Equations |
January 4, 2014, 03:38 |
Vino
I did not get the clear picture of Elliptic-parabolic system (incompressible) or Hyperbolic- parabolic system(compressible) of N.S equations. Let us say for a 2D case, N.S contains 1 continuity and 2 momentum equations. Among these, which will be elliptic/parabolic/hyperbolic? and these hyperbolic/parabolic with respect to time or space? Please provide me some material/reference to read... |
January 4, 2014, 06:01 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
The continuity equation is always hyperbolic (compressible or not flow model), the momentum equation is parabolic for unsteady viscous (compressible or not) flows but becomes hyperbolic for non-viscous flows. The mathematical classification of systems of PDE is a topic of applied mathematics but you can find also in CFD books some references. |
January 4, 2014, 08:10 |
Vino
Thank you Filippo Maria Denaro.
I am working on incompressible flow computation, i have read a paper recently which says "elliptic-parabolic nature of Incompressible N.S will become hyperbolic-parabolic when it becomes compressible". can you please clarify the following. 1) In case of Incompressible unsteady flow, will the continuity equation be hyperbolic?(no time derivative of density) 2) In case of Incompressible steady flow,will the momentum equation be parabolic? In most cfd books, i could find only the nature of general equations and i could not find anything about N.S system. If u particularly know some books, plz suggest.... |
January 4, 2014, 08:16 |
Rep Power: 71 |
1) yes, the continuity equation Div V =0 is hyperbolic, it will be then reorganized in the elliptic pressure equation
2) The Prandtl equations are parabolic in the momentum, while the full NS momentum equation are elliptic in the steady case |
January 4, 2014, 08:22 |
Vino
Thank you very much.!!!
January 7, 2014, 03:23 |
duri
For system of equation it is very difficult to say its kind. Because all equations are coupled. The best way is to find out the eigen value of the system which says system is elliptic or parabolic.
For NS equation, the eigen values are u+a, u-a, u,u,u. When they are positive definite then it is purely elliptic and when it becomes semi definite the it is parabolic. In case of subsonic flow these eigen values can take zero or positive quantity and so they are elliptic-parabolic system. |
January 7, 2014, 03:44 |
#7 | |
Rep Power: 71 |
January 7, 2014, 19:46 |
Vino
I understood the following.!!!
1) Unsteady Incompressible N.S will be Elliptic-parabolic type 2) Unsteady Compressible N.S will be Hyperbolic-parabolic type 3) Steady N.S (for Incompressible & Compressible) will be pure Elliptic type |
Type of PDE: Hyperbolic or Parabolic or Elliptic? | Guo | Main CFD Forum | 8 | August 17, 2018 09:34 |
Physics of Elliptic Parabolic and Hyperbolic Equations | Renjith | Main CFD Forum | 1 | December 4, 2013 04:04 |
parabolic nad elliptic scheme | shahrbanoo | Main CFD Forum | 1 | April 14, 2013 04:51 |
IdeasUnvToFoam Bug amp Fix | benru | OpenFOAM Bugs | 42 | November 13, 2009 07:59 |
Book on N.S. equations | J. McCarthur | Main CFD Forum | 3 | August 24, 1999 15:26 |
