February 3, 2014, 05:37 |
writing link between two CGNS files
Tom-Robin Teschner
Rep Power: 16 |
I am currently trying to output two separate CGNS files one of which contains the geometry (unstructured, 3D mesh) and the other the calculated solution (at a later stage transient data will be stored in separate CGNS files hence the linking to the geometry file). Unfortunately the documentation on links is rather poor, I have read the Users guide and mid level calls and consulted the SIDS documentation as well without luck. I was hoping someone has already done something similar and can look at my code, see below (I have shorten the subroutine just to see the writing / linking part. When I write everything into one file then it works so it is the linking which is giving me problems)
writing the geometry file Code:
SUBROUTINE WRITEGEOMETRY USE VARIABLES INCLUDE 'PANTARHEI.INC' C--Include CGNS here # include "../../libraries/cgnslib_3.1.4/src/cgnslib_f.h" CALL CG_OPEN_F('geometry.cgns', + CG_MODE_WRITE,INDEX_FILE,IER) BASENAME='BASE_GEOMETRY' ZONENAME='ZONE_GEOMETRY' ICELLDIM = 3 IPHYSDIM = 3 CALL CG_BASE_WRITE_F(INDEX_FILE,BASENAME, + ICELLDIM,IPHYSDIM,INDEX_BASE,IER) ISIZE(1,1)=NVERT_CGNS C--Number of Cells ISIZE(1,2)=NCELL_CGNS c--Number of Boundary Vertecis ISIZE(1,3)=0 C--Write Zone Node CALL CG_ZONE_WRITE_F(INDEX_FILE,INDEX_BASE, + ZONENAME,ISIZE,Unstructured,INDEX_ZONE,IER) C--Write GridCoordinate node CALL CG_GRID_WRITE_F(INDEX_FILE,INDEX_BASE,INDEX_ZONE, + 'GridCoordinates',INDEX_GRID,IER) C--Write Coordinates to CGNS CALL CG_COORD_WRITE_F(INDEX_FILE,INDEX_BASE, + INDEX_ZONE,RealDouble,'CoordinateX',XCGNS, + INDEX_COORD,IER) CALL CG_COORD_WRITE_F(INDEX_FILE,INDEX_BASE, + INDEX_ZONE,RealDouble,'CoordinateY',YCGNS, + INDEX_COORD,IER) CALL CG_COORD_WRITE_F(INDEX_FILE,INDEX_BASE, + INDEX_ZONE,RealDouble,'CoordinateZ',ZCGNS, + INDEX_COORD,IER) C--Now write the connectivity required for unstructured meshes CALL CG_SECTION_WRITE_F(INDEX_FILE,INDEX_BASE,INDEX_ZONE, + 'Elements',HEXA_8,1,ISIZE(1,2),0,IVCELL_CGNSTEMP, + INDEX_SECTION,IER) C--Coordinated have been written to CGNS file, closing file CALL CG_CLOSE_F(INDEX_FILE,IER) END And the Flow solution file, linking to the geometry file Code:
SUBROUTINE WRITETOCGNS USE VARIABLES INCLUDE 'PANTARHEI.INC' C--Include CGNS here # include "../../libraries/cgnslib_3.1.4/src/cgnslib_f.h" C--Convert timestep to string CURRENTTIMESTEP = LASTTIMESTEP + NTIMSTEP WRITE(INT2STR,'(I7.7)') CURRENTTIMESTEP FILENAME = 'result' FILENAME = trim(FILENAME) // INT2STR(:7) // '.cgns' C--Create and open CGNS result file for specified timestep here CALL CG_OPEN_F(FILENAME,CG_MODE_WRITE,INDEX_FILE,IER) ICELLDIM = 3 IPHYSDIM = 3 CALL CG_BASE_WRITE_F(INDEX_FILE,'BASE_RESULT', + ICELLDIM,IPHYSDIM,INDEX_BASE,IER) C--Number of Vertecis ISIZE(1,1)=NVERT_CGNS C--Number of Cells ISIZE(1,2)=NCELL_CGNS c--Number of Boundary Vertecis ISIZE(1,3)=0 C--Write Zone Node CALL CG_ZONE_WRITE_F(INDEX_FILE,INDEX_BASE, + 'ZONE_RESULT',ISIZE,Unstructured,INDEX_ZONE,IER) C--Link GridCoordinate node CALL CG_GOTO_F(INDEX_FILE,INDEX_BASE,IER, + 'Zone_t',1,'end') CALL CG_LINK_WRITE_F('GridCoordinates', + 'geometry.cgns', + 'BASE_GEOMETRY/ZONE_GEOMETRY/GridCoordinates',IER) CALL CG_SOL_WRITE_F(INDEX_FILE,1,1,'FlowSolution', + CellCenter,INDEX_FLOW,IER) C--Output Pressure to CGNS CALL CG_FIELD_WRITE_F(INDEX_FILE,1,1,INDEX_FLOW,RealDouble, + 'Pressure',PCGNS,INDEX_FIELD,IER) C--Output Velocities to CGNS CALL CG_FIELD_WRITE_F(INDEX_FILE,1,1,INDEX_FLOW,RealDouble, + 'VelocityX',U1CGNS,INDEX_FIELD,IER) CALL CG_FIELD_WRITE_F(INDEX_FILE,1,1,INDEX_FLOW,RealDouble, + 'VelocityY',U2CGNS,INDEX_FIELD,IER) CALL CG_FIELD_WRITE_F(INDEX_FILE,1,1,INDEX_FLOW,RealDouble, + 'VelocityZ',U3CGNS,INDEX_FIELD,IER) C--Close result filere here CALL CG_CLOSE_F(INDEX_FILE,IER) END By the way, if I do Code:
CALL CG_OPEN_F(FILENAME,CG_MODE_READ,INDEX_FILE_LINK,IER) CALL CG_GOTO_F(INDEX_FILE_LINK,1,IER, + 'Zone_t',1,'end') CALL CG_LINK_READ_F(FILENAME,LINK_PATH,IER) Last edited by t.teschner; February 3, 2014 at 06:44. |
February 4, 2014, 10:26 |
Tom-Robin Teschner
Rep Power: 16 |
Solved it. Just in case somebody has the same problem and stumbles upon it, in my case I have an unstructured mesh and forgot to link the connectivity array (the look up table if you want).
cgns, link |
Error writing files while calculating | ehfeinberg | FLUENT | 0 | July 9, 2013 14:44 |
parallel support with CGNS format not yet implemented | kirkrich | SU2 | 3 | January 18, 2013 15:39 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems with result files | Kasper | CFX | 5 | December 14, 2006 02:41 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
