Definition of propulsive efficiency
Old   February 10, 2007, 22:59
Default Definition of propulsive efficiency
zonexo
I'm trying to find out how to obtain propulsive efficiency, n for a pitching, heaving and sweeping airfoil.
From some references, I managed to get these formulas:
n = power input / power output ( p(out) / p(in) )
p(out) = thrust (T) * u velocity
p(in) = -Lift (L)(t)*dh/dt - Moment (M)(t)*d(theta)/dt
There's something which I don't understand.
h in dh/dt in the reference is given as the heaving height. If there is sweeping (moving the airfoil in the x-direction) involved, will the definition change?
Given the point of pitching, how should the moment be calculated?
Is it given by
M = L*x-T*y where x,y are the horizontal and vertical distance of the airfoil's CG from the point of pitching respectively?
Thank you
Old   February 10, 2007, 23:13
Default Re: Definition of propulsive efficiency
zonexo
Oh ya,
do I need to modify for a case which includes sweeping to become
p(in) = -Lift (L)(t)*dh(y)/dt - Moment (M)(t)*d(theta)/dt - Thrust (T)(t)*dh(x)/dt
where h(x) is the horizontal sweeping displacement and h(y) is the vertical one.
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Efficiency, thrust/drag with regard to hovering quarkz Main CFD Forum 0 April 21, 2010 00:51
Parelleling Efficiency kassiotis OpenFOAM 0 June 19, 2009 14:12
Efficiency for hovering flight? Zonexo Main CFD Forum 1 April 14, 2008 00:49
Negative propulsive efficiency of a moving airfoil zonexo Main CFD Forum 4 March 7, 2007 00:16
