Fortran Warning and error
Old   March 9, 2007, 15:54
Default Fortran Warning and error
M.M
Hello All,
I've got this warning when I ran my code in Fortran: "warning LNK4084: total image size 377360384 exceeds max (268435456); image may not run" What is this warning and how it could be fixed.
Thanks M.M
Old   March 10, 2007, 09:19
Default Re: Fortran Warning and error
buch
I guess you are using visual fortran under windows. I think this message comes from the limitations of old operating systems (i.e. windows 98 ...) that did not accept executables bigger than 256Mb. "image may not run" => if it runs, do not pay to much attention to it
Regards
Old   March 10, 2007, 18:28
Renato.
Your warning is due to lack of memory to load your program due to the size of the memory fixed allocated. You can work out it by using dynamic memory allocation (it's a Fortran 9X feature, so, don't try to do it with old F77 compilers). You can do it according to the following example.
! fixed allocated real*8 :: HugeArray(1000000000)
! dynamica array real*8, allocatable :: HugeArray( n = 10000000 allocate(HugeArray(n))
! use your HugeArray
! Freeing the memory previously allocated
deallocate(HugeArray)
Cheers
Renato.
Old   March 12, 2007, 10:24
jojo
You must have a stack size option somewhere in your compiler. Simply increase with respect to the default value (usually 2MB).
Old   July 28, 2009, 13:57
Default Fortran warning
snow-white is on a distinguished road
Hi
I have this warning when I compile my code:
A jump into a block from outside the block may have occurred"
How could I fix it?
Thanks,
snow
snow-white is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
