Hi, I have tried to achieve a mesh where y+ is < 1 for airfoil analysis, although found that an excessive number of nodes are required. This is based on the requirement that the aspect ratio of cells within the BL cannot exceed 10. As a result i have specified a constant interval size on the surface such that the normal wall distance is within an allowable limit based on the required y+ value and that the width of the node points on the surface give an AR of 10 (which i was told is the maximum allowable limit for DES analysis). I have found, although possible, the total number of nodes required on the airfoil alone are in excess of 4000-5000 is some cases!!! I am not sure if i am adopting a correct method in the way i mesh my airfoil, so would be interested to know how people have gone about this problem. is there an alternate method which can improve this?
theoritically DES is made to remove this kind of limitation. In LES you must ensure that the AR is limited to capture all the turbulent eddies, but since, in DES, your boundary layer zone is resolved using the RANS equations (Spalart-allmaras) there is no limitation on the AR. Nevertheless try to use values smaller than 1000, and refine your mesh at the leading and trailing edges. Moreover, you should use a progression ratio (ratio between h1 and h0, hn and h(n-1)) no larger than 1.25.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] 3D mesh of airfoil from 2D | TKE | ANSYS Meshing & Geometry | 4 | October 7, 2011 05:34 |
dynamic mesh airfoil oscillation | aamer | Fluent UDF and Scheme Programming | 0 | January 25, 2011 07:29 |
Mesh Airfoil in ICEM | student123a | ANSYS | 3 | January 24, 2010 11:54 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
