Effect of Grids on Solution
Old   May 11, 2007, 04:37
Default Effect of Grids on Solution
Andrea
If a CFD solution shows the footprint of the mesh (especially at the shared patches/edges in multi-block structured grids), what would be the reason and how can I fix it? This hapens only in some part of the domain, not everywhere.
Thanks, Andrea
Old   May 11, 2007, 05:06
Default Re: Effect of Grids on Solution
to
Real CFD problem or just visualisation flaw ?
Old   May 11, 2007, 08:16
Mani
Are these matching interfaces (e.g. each cell on block 1 connects to a cell on block 2), are they non-matching, overlapping (chimera).... ?
How are the interface conditions defined. Do you use ghost cells?
Here is what you can do as a check: Run a simple case (e.g. a 2D airfoil) on a single block. Then decompose the single block into a number of smaller blocks and run the code in multiblock mode. These two converged solutions must be identical!
Old   May 11, 2007, 16:13
Sue
Well, I assume it seems to be a CFD problem, as I use TECPLOT for visualisation, so that front should be ok. Right?
Old   May 11, 2007, 16:14
Sue
I agree with Sue.
Andrea
Old   May 11, 2007, 16:19
Andrea
This is not the first case that I run this code for, in previous cases it was great, the properties transfer very nice and smoothly between the blocks. Even in this case, it works well in other parts of the domain (other blocks). I am just wondering why this is being happened in some (but important) regions.
Andrea
Old   May 13, 2007, 21:34
ag
Do you have strong gradients in this region that don't appear elsewhere, or in your previous solutions? If so, you may still have problems in how you are transferring information that only show up when strong gradients are present. Some transfer schemes work well in regions of weak gradients and not so well in regions of strong gradients.
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Integration along a line during solution DaRumpel CFX 16 September 2, 2010 11:17
Doubt on Implicit Methods analyse In India Main CFD Forum 10 March 9, 2007 03:01
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
