Unsteady pressure calculation
Old   May 1, 2014, 22:05
Default Unsteady pressure calculation
Fraser Callaghan
fraser29 is on a distinguished road
I have a temporal dataset of velocity vectors in a 3D volume. I also have a reference pressure at t=0. My flow is incompressible.
I can calculate the pressure gradient and define a pressure field relative to my reference pressure at t=0, however how could I calculate pressure fields at t=1, t=2, t=i ... ?
(I have the pressure gradient fields at all these time points, but no reference pressure).
Any tips, resources would be helpful. I haven't been able to turn up anything in the literature.
Thanks,
Fraser
fraser29 is offline   Reply With Quote
Old   May 3, 2014, 18:33
leflix is on a distinguished road
Did you solve the Navier-Stokes equations? if so ,necessary you have the pressure on each grid point of your computational domain.
If it is not the case,you need a spatial reference pressure for each time step (if you have the pressure gradient at each time step)
Thanks,
Fraser
leflix is offline   Reply With Quote
Old   May 4, 2014, 03:34
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks,
Fraser
1) for any time, solve a Poisson equation with the source terme obtained taking the divergence of the momentum equation.
2) However, for incompressible flows be careful that you do not define a thermodicamic pressure
FMDenaro is offline   Reply With Quote
Old   May 4, 2014, 17:58
Fraser Callaghan
Thanks for the reply.
Velocities are measured velocities. Pressure gradient is solved for from the momentum equations. I have no reference pressure for each time step.
Approach so far is an implicit discretisation based on SIMPLE
Old   May 4, 2014, 23:11
agd
agd is on a distinguished road
Why can you not use the same reference pressure as at t = 0? What is causing the reference pressure to change?
agd is offline   Reply With Quote
Old   May 4, 2014, 23:51
Fraser Callaghan
A beating heart
Old   May 5, 2014, 08:23
agd
But ordinarily the reference pressure is a quantity that primarily affects the non-dimensionalization of the equations of motion. The actual pressure in a heart chamber will vary in time, but the pressure levels will vary relative to the reference pressure. So I guess I still don't understand how or why the reference pressure is changing in time.
Old   May 5, 2014, 09:54
the blood pressure is measured by the device with reference to a pressure value, you should use this one...
Old   May 8, 2014, 20:34
Fraser Callaghan
Sorry - grant deadlines
The velocities are measured and thus should be non-divergent - solution of Poisson eqn not required.
I don't want to know pressures relative to single point at each time step. I want to know pressures relative to single point at time step one. All pressures, everywhere are time dep. Reusing ref pressure from t=0 would give me the former case.
Thus I need some sort of coupling of the pressure gradient to the unsteady component.
Old   May 9, 2014, 03:24
You can always write
Div (Grad p') = Div ( diffusion - convection - acceleration)
so, if you have a non divergence-free acceleration you can compute it (you have the velocity ad several time steps, right?) and consider it in the source term.
incompressible, navier-stokes, pressure, unsteady
[Help!] impeller torque calculation: pressure and viscous moments ghost82 Main CFD Forum 1 March 27, 2014 02:37
reference pressure and compressible flow bingo10 CFX 0 September 11, 2013 07:32
Unsteady pressure pulses delaneyluke FLUENT 0 February 19, 2013 15:17
Pressure drag calculation lc05 Main CFD Forum 2 November 1, 2010 07:50
pressure drop calculation multi-inlet-outlet syst. timmyy FLUENT 1 April 24, 2007 06:03
