May 1, 2014, 22:05 |
Unsteady pressure calculation
Fraser Callaghan
Rep Power: 12 |
I have a temporal dataset of velocity vectors in a 3D volume. I also have a reference pressure at t=0. My flow is incompressible.
I can calculate the pressure gradient and define a pressure field relative to my reference pressure at t=0, however how could I calculate pressure fields at t=1, t=2, t=i ... ? (I have the pressure gradient fields at all these time points, but no reference pressure). Any tips, resources would be helpful. I haven't been able to turn up anything in the literature. Thanks, Fraser |
May 3, 2014, 18:33 |
#2 | |
Rep Power: 15 |
Did you solve the Navier-Stokes equations? if so ,necessary you have the pressure on each grid point of your computational domain.
If it is not the case,you need a spatial reference pressure for each time step (if you have the pressure gradient at each time step) Quote:
May 4, 2014, 03:34 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
1) for any time, solve a Poisson equation with the source terme obtained taking the divergence of the momentum equation. 2) However, for incompressible flows be careful that you do not define a thermodicamic pressure |
May 4, 2014, 17:58 |
Fraser Callaghan
Rep Power: 12 |
Thanks for the reply.
Velocities are measured velocities. Pressure gradient is solved for from the momentum equations. I have no reference pressure for each time step. Approach so far is an implicit discretisation based on SIMPLE |
May 4, 2014, 23:11 |
Rep Power: 18 |
Why can you not use the same reference pressure as at t = 0? What is causing the reference pressure to change?
May 4, 2014, 23:51 |
Fraser Callaghan
Rep Power: 12 |
A beating heart
May 5, 2014, 08:23 |
Rep Power: 18 |
But ordinarily the reference pressure is a quantity that primarily affects the non-dimensionalization of the equations of motion. The actual pressure in a heart chamber will vary in time, but the pressure levels will vary relative to the reference pressure. So I guess I still don't understand how or why the reference pressure is changing in time.
May 5, 2014, 09:54 |
Rep Power: 71 |
the blood pressure is measured by the device with reference to a pressure value, you should use this one...
May 8, 2014, 20:34 |
#9 |
Fraser Callaghan
Rep Power: 12 |
Sorry - grant deadlines
The velocities are measured and thus should be non-divergent - solution of Poisson eqn not required. I don't want to know pressures relative to single point at each time step. I want to know pressures relative to single point at time step one. All pressures, everywhere are time dep. Reusing ref pressure from t=0 would give me the former case. Thus I need some sort of coupling of the pressure gradient to the unsteady component. |
May 9, 2014, 03:24 |
#10 | |
Rep Power: 71 |
You can always write Div (Grad p') = Div ( diffusion - convection - acceleration) so, if you have a non divergence-free acceleration you can compute it (you have the velocity ad several time steps, right?) and consider it in the source term. |
incompressible, navier-stokes, pressure, unsteady |
[Help!] impeller torque calculation: pressure and viscous moments | ghost82 | Main CFD Forum | 1 | March 27, 2014 02:37 |
reference pressure and compressible flow | bingo10 | CFX | 0 | September 11, 2013 07:32 |
Unsteady pressure pulses | delaneyluke | FLUENT | 0 | February 19, 2013 15:17 |
Pressure drag calculation | lc05 | Main CFD Forum | 2 | November 1, 2010 07:50 |
pressure drop calculation multi-inlet-outlet syst. | timmyy | FLUENT | 1 | April 24, 2007 06:03 |
