LES
Old   June 14, 2007, 09:17
Default LES
John Deas
Hi, if I want to save all the information about the state of a field calculated with a k-e model, I have to save the pressure, velocity k and e at each point.
Now, if I would like to take the same kind of snapshot but for a LES-calculated flow, what variables must I store ?
thanks,
John Deas
Old   June 14, 2007, 12:58
Default Re: LES
Lionel Larchevêque
As for RANS, the number of variable to store is related to the (subgrid) model you are using. Since almost all LES models are of 0-equation kind, you should have to store the velocity components and the pressure (and density for compressible flows, ...)
Regards,
Lionel
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 05:05
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
