June 13, 2014, 03:00 |
Regarding Coding in CFD
AB
If I want to access the CFD code in any commercial Software, Then How should I do the same?
What are basic prerequisites for CFD coding? Usaully in which Language the codes have been written?? |
July 20, 2014, 13:56 |
#2 | |
generally commercial codes allows simple coding adding in their software through user defined funtions. In Ansys Fluent it's a kind of C language In Star CCM+ it is in fortran I think. |
July 22, 2014, 13:18 |
Jack Chilvers
Rep Power: 12 |
Fluent allows access to flow variables and parameters using the UDF framework. Obviously this won't help you if you're looking to see the 'nuts and bolts' of the solver itself, but it does provide a useful way of adding on your own pieces of code.
Pre-defined macros allow access to solver variable quite intuitively and also includes loops across the entire domain. I hope that goes some way to answering your question! |
July 22, 2014, 14:20 |
Mehdi Asghari
By using OpenFoam CFD code ,yoy can access open cfd source codes even for main routines
cfd coding | ddhinglajia | Main CFD Forum | 1 | October 29, 2010 08:23 |
Is CFD coding in finite element method a formidable job? | bearcat | Main CFD Forum | 0 | June 18, 2010 20:53 |
CFD Coding | easy_astronaut | Main CFD Forum | 6 | June 14, 2010 13:05 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
