Two-sided walls
Old   July 5, 2014, 14:44
Smile Two-sided walls
Jian
Jordi P. is on a distinguished road
I'm trying to understand what's the difference between the originally wall that I have defined in my domain and the automaticly created "Shadow Wall".
I have a wall in contact to a fluid zone but this wall is coated" with a small sheet.
Then I have two wall next to the fluid, the originally one and his Shadow, and I have to define the thickness of the sheet, and here is the problem; I have to define the thickness in the originally zone or in the shadow zone?.
And... the shadow zone is nearer of the solid or of the fluid?.
I'll be grateful to someone who can helps me!
Regards!
Jordi P. is offline   Reply With Quote
Old   July 13, 2014, 03:30
Thumbs up
Ashutosh
dreamz is on a distinguished road
Well I think you put one of your original walls as interface. Fluent automatically creates a shadow wall in that case. Or, if in your geometry you combine all of your parts then at those walls where your fluid and solid zones interact, shadow wall is created by fluent. This shadow wall or two-sided wall acts as coupling between the solid and fluid zone. e.g. if one is modeling conjugate heat transfer, then to creation of shadow walls instructs fluent to consider the conduction within the solid and the convection to the fluid.
I think you must put your thickness to the original wall although, I request you to share your geometry and description of the problem so that we can get a clear picture.
dreamz is offline   Reply With Quote
[Gmsh] Boundary Layer Mesh in GMSH Medu OpenFOAM Meshing & Mesh Conversion 1 September 1, 2021 03:43
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 12:51
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 11:49
thermal conditions of walls Stefan FLUENT 2 March 23, 2003 06:17
