Convergence clue
Old   July 28, 2014, 14:12
Default Convergence clue
Иван Сташко
ivan-s is on a distinguished road
I'm working on a fairly simple plenum with a bunch of tubes attached to it. It's a kind of precipitator.
Flow is turbulent. The plenum is 5m x 8m x 2m, with a couple of hundred 0.1m x 3m tubes coming out of it. The plenum has an inlet perpendicular to the tube bank. Hopefully after I get it to converge I'll begin to add barriers inside the plenum to adjust the flow to the tubes. At this point I'm not even including the outlet plenum in the model.
The thing is very hard to get to converge. I've tried both k-e and k-w models. The maximum size of the elements in the plenum is now 0.02m, so there are well over 10^7 elements.
I'm not sure what to try next to get this to converge. Any advice would be greatly appreciated.
ivan-s is offline   Reply With Quote
Old   July 29, 2014, 16:19
Default Technique
Иван Сташко
I seem to have found a technique, to use the time dependent solver.
convergence problem
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
