Dye diffusion in a stationary fluid
Old   August 21, 2014, 06:48
Default Dye diffusion in a stationary fluid
Kunal Bhoyar
kunalrb5 is on a distinguished road
I am very new to CFD. I am working on project in which I need to simulate the diffusion of dye in a Nanofluid. So how should I start off this problem?
Note: the fluid is stationary in a box and a pulse input of a dye is given at the center of the box.
kunalrb5 is offline   Reply With Quote
Old   August 21, 2014, 09:17
Michael Prinkey
mprinkey will become famous soon enough
If the "squirt" of dye has no significant momentum, you call solve this problem using any diffusion/heat equation solver. That includes all finite element and finite volume CFD codes. For a quick (and free) way to get started, download OpenFOAM and run through the tutorials and focus on ScalarTransportFoam. That solves the unsteady diffusion equation. To make the fluid stationary, set the mass flux field (phi) and velocity field (U) to zero.
mprinkey is offline   Reply With Quote
Old   August 22, 2014, 05:39
Default Nanofluid and Diffusion coefficient
Kunal Bhoyar
Thanks for your reply. Yes the squirt can be assumed insignificant but what about the nanofluid? Can we simulate the nanofluid (basically a base fluid containing suspended nanoparticles)?
I want to see the enhancement of mass transfer in nanofluid as compared to normal base fluid. So ultimately I will be needing the diffusion coefficient for the case of dye diffusion in nanofluid as well as base fluid so as to do the comparison.
Old   August 22, 2014, 08:47
Michael Prinkey
The diffusivity is an input to any CFD code. So, the base fluid and nanoparticle suspension will have different diffusivities that need to be measured. Perhaps there is theory that can produce modifications to the base diffusivity based on the nanoparticle properties. Honestly, the CFD simulation you are describing is very simple. If the simulation is 3d, you will see spherically symmetric transient result that can probably be solved with analytical techniques, or, at worst, a 100 lines of transient 1D code--I would not call that CFD.
If you are looking for meso- or microscale simulations of the dye interaction with the base fluid and nanoparticles, you may well need to look at molecular dynamics codes instead.
Old   August 25, 2014, 02:23
Kunal Bhoyar
Hi Michael,
Actually I don't at all want to look at any interaction between dye and fluid/ particles, rather I would assume it to be negligible. My sole purpose is to find out the enhancement in mass transfer due to the presence of Nanoparticles.
If I input the diffusivity value by using any theoretical correlation then it already assumes the enhancement phenomena. Therefore the CFD results will obviously show an enhancement in mass transfer.
What I want to study is the effect of Brownian motion of nanoparticles on the mass transport phenomena in any base fluid and according to literature, we expect an enhancement. I don't want to presume the enhancement but want to observe it as a result of the Brownian motion of the nanoparticles. So is there any way by which I could track the enhancement? as I thought, effective diffusivity is the only parameter which would tell us the relevant information.
I hope now you have a clear vision over my problem statement.
Thanks again for helping
Old   August 25, 2014, 12:36
Michael Prinkey
Most CFD codes start with equilibrium pressure, density, and velocity as the solved variables. There are no distribution functions, no statistical behavior at all (apart from bulk scale turbulence, etc.) If you want to model Brownian motion, you will need to look at either molecular dynamics (direct Lagrangian simulation of fluid, dye, and nanoparticles) or Boltzmann/Fokker–Planck formulations. There are techniques of CFD that can inform the solution of those systems, but you can't start with Ansys FLUENT or OpenFOAM standard solvers and get the results you are looking for.
For molecular dynamics, you might look at LAMMPS (http://lammps.sandia.gov/). I can't recommend any Eulerian non-equilibrium solvers.
diffusion, dye, nanofluid, stationary fluid
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 11:16
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 13:57
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
elastic cylinder in stationary fluid doctsh ANSYS Meshing & Geometry 0 January 9, 2010 03:47
Fluid Dynamics Eng - PAX Mixer - San Rafael, CA Gary Jong FLUENT 0 February 25, 2008 20:46
