Number of Rays' meaning?
Like Tree1Likes
  • 1 Post By Rami
Old   September 13, 2014, 04:34
Default Number of Rays' meaning?
V and V
largehadron is on a distinguished road
Can somebody explain for me the meaning of « Number of Rays » in Thermal Radiation models and how to choose an appropriate number in different cases? Any suggestion would be greatly appreciated.
largehadron is offline   Reply With Quote
Old   October 2, 2014, 07:08
Rami Ben-Zvi
Rami is on a distinguished road
Hi largehadron,
The Monte Carlo method used for radiation simulation uses random numerical rays, which issued at boundaries and traced along their path. The more rays used the closer one gets to the exact solution, as the statistical error is approximately proportional to N^(-1.5), where N is the number of rays. The way to determine N is to start wit a small value (say 1e4) and solve, then use a sequence of higher values (say, 1e5, 1e6, ...) and see when you a solution that does not change significantly with further increase of N.
largehadron likes this.
Rami is offline   Reply With Quote
Old   October 3, 2014, 01:27
V and V
Thanks Rami for the clear and helpful explanation!
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries vkrastev OpenFOAM Pre-Processing 7 June 2, 2016 15:50
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
error in parallel run immortality OpenFOAM Running, Solving & CFD 7 January 1, 2013 13:35
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
