pressure boundary condition
Old   October 29, 2007, 07:54
Default pressure boundary condition
kharati
What would be pressure boundary condition on airfoil surface that oscillates in inviscid and viscous fluid flow? please send me a paper regarding this subject.
Old   October 29, 2007, 10:42
Default Re: pressure boundary condition
Harish
That would depend on what kind of solver you are using and what velocity components that you use.A neumann boundary condition of dp/dn=0 or extrapolation seems to work.But it again depends on the details of your solver.
Old   October 29, 2007, 18:53
zonexo
Hi, I've been using dp/dn=0 in oscillating airfoil. However, some other ppl had used dp/dn=-(Du/Dt).n, where Du/dt is the material derivative and n is the normal. Is this a more accurate BC?
Thanks
Old   October 29, 2007, 18:59
ag
Yes, the pressure gradient should be balanced by the normal acceleration. That's what the normal momentum equation can be approximated by at the boundary.
Old   November 3, 2007, 09:42
kharati
How can we calculate Du/Dt on an oscillating airfoil surface?
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
Pressure boundary condition C-H Kuo Main CFD Forum 18 September 16, 2016 03:19
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Pressure Boundary condition abishek FLUENT 1 July 28, 2008 08:14
