non-planar faces due to the deformation of grid
Old   November 11, 2007, 16:30
Default non-planar faces due to the deformation of grid
gonski
Hi,guys.
I would appreciate your help.I found sometimes my CFD grid have a big deal of nonplanarity due to the deformation/twist of the grid. I mean sometime rectangular cell faces are not not plane surfaces. So how this will affect the solution of fluid flow.
Thanks in advance
Regards,
gonski
Old   November 11, 2007, 21:43
Default Re: non-planar faces due to the deformation of gri
Ahmed
what is needed is the cell surface area, so how much is the difference between the real surface area and the calculated surface area ? (which depends on the coordinates of the vertices)
Old   November 11, 2007, 21:50
gonski
What kind of trouble can be observed in the solution of fluid flow?
Old   November 12, 2007, 05:21
gonski
Interesting, I try to search some proofs for this non-planar problem in this whole day, and get nothing. There are one or two papers in finite element method discussing the problem. However their explanations are not convincing. Now everything push me to believe that non-planar faces should be no problem in finite volume method as no one talk about this problem. I would appreciate your comments.
Best regards,
Gonki
Old   November 12, 2007, 09:46
Tom
The usual trick is to split the face into two triangles and define the normal to the face to be the average of the normals to the two triangles. If these two normals are very different (so that it effects your answer) then your grid needs smoothing (to the point where the error induced is comparable to the discretization error).
Old   November 12, 2007, 15:25
gonski
Thanks a lot! Tom and Ahmed
Mapping results from CFD grid to structural grid of a free-form surface mbecker OpenFOAM Running, Solving & CFD 1 October 18, 2013 10:16
Gambit/Fluent Grid Issues Jasperdrums FLUENT 2 September 14, 2010 19:24
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Grid deformation for fluid-structure interation javier FLUENT 0 March 10, 2004 13:25
Algebraic Multigrid for nonuniform grid Joshua Lee Main CFD Forum 4 March 16, 2000 13:05
