Flux calculation using Riemann Solvers for non-Cartesian grid.! |
November 10, 2014, 17:46 |
Vino
I would like to clarify how to calculate flux at the interface using Riemann solver (say HLL) for Euler equation(2D). I am able to understand the flux calculation method for 2D-cartesian grids. In case of non-Cartesian gird, can someone tell me how to calculate the flux? Is the formulation correct which I have shown below for Riemann solvers(for any non-Cartesian edge)? F1= rho*Un F2=rho*U*Un+p*nx F3=rho*V*Un+p*ny F4=rho*E (U-x velocity,V-y velocity, Un-velocity normal to the edge) or Do I need to calculate like this? Calculate Un and Ut Then calculate flux using Un & Ut F1= rho*Un F2=rho*Un*Un+p F3=rho*Ut*Un F4=rho*E then convert it back to original coordinate as follows F1=F1 F2=F1*nx-F2*ny F3=F1*ny+F2*nx F4=F4 Whether these both are same? Do both hold true for flux calculation using Riemann Solvers? Thanks in advance.!!! Last edited by Vino; November 11, 2014 at 11:42. |
Flux calculation in vertex-centered finite volume. | Martin | Main CFD Forum | 3 | June 4, 2008 10:04 |
cartesian grid generation method | Abu Taleb | Main CFD Forum | 7 | April 14, 2001 09:49 |
Cartesian grid generation method | Abu Taleb | Main CFD Forum | 0 | April 8, 2001 12:03 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
Non-uniform grid calculation | Aspens | Main CFD Forum | 1 | February 23, 2000 14:15 |
