LES
Old   December 3, 2007, 06:00
Default LES
John Deas
I would like to study decay of vortices structures behind a vortex generator at Re_bulk=5000 in a plain channel, isn't LES a bit of an overkill there ?
Old   December 3, 2007, 17:27
Default Re: LES
pankaj saha
hi, i also work on LES. But what exactly, your problem is? Can you tell?
Old   December 4, 2007, 07:51
Default Re: LES
John Deas
I would like to quantify the viscous dissipation of the structures behind the winglet and link it with the heat transfer. I would like to compare stationnary RANS and non stationnary calculations.
Old   December 4, 2007, 17:00
Default Re: LES
pankaj saha
which type of winglet u are using...delta wing or winglet pair....Which paper you would like to compare , related to RANS?
Old   December 6, 2007, 23:37
Default Re: LES
agg
If I understant correctly, your Re_bulk is not very high. Can you not attempt a DNS? If DNS resolution requirements are too high, I think attempting LES is quite reasonable. If you could explain why you think LES for this is an overkill, I might be able to explain better.
Old   December 7, 2007, 03:37
Default Re: LES
John Deas
I want mainly to compare with "Heat transfer in a rectangular channel with a vee-shaped vortex generator" by Sohankar. However, I have a single delta winglet while he have two. He uses dns and LES, and found the results comparables.
Old   December 7, 2007, 03:38
Default Re: LES
John Deas
I thought LES was interesting for high Reynolds numbers (more than 10000), but for less, RANS and URANS might be sufficient.
Old   December 7, 2007, 17:08
Default Re: LES
agg
Yes that is correct. So, with the present computational power, computing DNS for your case should not be much effort, don't you think?
Old   December 25, 2007, 16:18
Default Re: LES
pankaj saha
hi, For the winglet problem....Do, anyone need to satisfy Y+=1 around the winglet body also? as near the wall it must be a criterion for les? Can anyone tell what is the reason?
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 05:05
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
