vertices coordinates of a geometry domain
Old   December 16, 2007, 06:24
Default vertices coordinates of a geometry domain
dikra
hellow, i whould like to know how to obtain the vertices coordinates of a rectangular geometry domain in order to compute the aerodynamic performances of a symmetrical NACA airfoil.please, i will be very grateful to receive any idee or commentary .thanks.
Old   December 19, 2007, 11:34
Default Re: vertices coordinates of a geometry domain
Praveen. C
Are you asking how to choose the location of outer boundary ? That depends on your outer boundary condition. If you just keep the flow solution fixed, then you need to put the boundary at a very large distance from the airfoil, something like 100 chord. If you use a good boundary condition like those based on characteristics then you could put it closer. Using a point vortex correction allows to put the boundary still close something like 20 chords away. You can experiment for yourself. Compute lift and drag coefficients with different outer boundary locations and see how they vary.
Old   December 20, 2007, 16:26
dikra
wellcome Praveen. To explain, I have to create script files (file.txt), which can be read in ICEMCFD, in order to generate geometry, domain of computing and create mesh. I have done the aerofoil family. But to define: paroi 1 , paroi 2, inflow and outflow families I have difficulties to get the vertices(4) (x, y)coordinates of the rectangular( or square) domain of computing.I have idea to compute them with consideration of:c=100mm,longer of(square)domain=10c.In this case i need to know how to compute the (x,y) of the center of gravitation of the aerofoil.thanks in advance.
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Looking for Pak-B LPT blade geometry coordinates yossarian88 Main CFD Forum 1 August 16, 2011 11:40
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
building 3D geometry from a huge list of vertices S.S. Main CFD Forum 3 July 29, 2003 03:55
