viscous wall boundary condition
Old   January 2, 2008, 01:31
Default viscous wall boundary condition
shuo
How can I implement a wall boundary condition for compressible Navier-stokes equations in conservation forms? In the solution vectore there is only density, pressure velocity. What about the temperature?
Thanks Shuo
Old   January 2, 2008, 09:12
Default Re: viscous wall boundary condition
Harish
Usually you assume the wall is either isothermal or adiabatic or define the heat transfer explicitly. Depending on the case, which suits your problem, you assign the boundary condition for temperature.
UDF setting wall boundary condition with a DEFINE_PROFILE NLao FLUENT 3 September 2, 2019 00:33
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
wall boundary condition in UDF ssamton FLUENT 0 January 31, 2011 03:07
applying boundary condition on rotating wall Haris Maharana Siemens 2 January 16, 2001 12:03
