About CFL number !
Old   January 8, 2008, 08:26
Default About CFL number !
emca
The CFL number is function of three parameters, it's found for controller that the scheme is stable. The choice of the CFL infect the space time. In case of Roe scheme, the scheme is stable for 0 < CFL <=1. So far I think that all fine. In some meshes there will be no stable for value lower than 1, but they still need to be small, and even if it was in this interval was not necessarily stability
Could you explain it ! thanks
Old   January 19, 2008, 22:29
Default Re: About CFL number !
Usman
Are you using FVM code or finite difference code. Low courant number is not a stability requirement for FVM codes.
Usman
Old   January 21, 2008, 09:09
ag
That's not correct. A low CFL number is not a stability requirement for implicit schemes, but an explicit FV scheme will still be CFL-limited.
Old   January 23, 2008, 18:16
Usman
ag is right! Sorry about that. For some reason i mixed up FV with implicit scheme.
Usman
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
CFL number specification sonic/supersonic flow gr Main CFD Forum 0 January 16, 2009 11:14
high cfl number and discretization scheme Fab Main CFD Forum 0 March 2, 2008 12:19
About Courant (CFL) number Jason Main CFD Forum 2 March 17, 2003 11:11
