Solver selection of supersonic compressible flow
Old   December 17, 2014, 21:13
Default Solver selection of supersonic compressible flow
Leeoo
Leeoo is on a distinguished road
Dear Friends:
This is my frist time posting a thread.
I am simulating the supersonic compressible flow and I have tried the Density-Based Solver(DBS) and Pressure Based Solver(PBS), but the simulation resaults via the two solver were very diiferent. I really did not know why and which solver was suitable. I've been confused for a long time and is very eager to get help.
Leeoo is offline   Reply With Quote
Old   December 17, 2014, 22:45
Troy Snyder
tas38 is on a distinguished road
Originally Posted by Leeoo View Post
Dear Friends:
Pressure based solvers are generally more suited for only "mildly" compressible flows, say up to Mach 0.3. Beyond this value, density based solvers are typically preferred.
tas38 is offline   Reply With Quote
Old   December 17, 2014, 23:03
Leeoo
Thank you for your advise. Another question:Are these two solvers will lead to different results?
Old   December 18, 2014, 21:42
Troy Snyder
I believe the main issue using pressure based for high Mach number flows and likewise using density based solvers for low Mach number flows has to do with efficiency rather than accuracy. Density based solvers become very stiff as the Mach number decreases as the incompressible limit is approached. However, there are some specialized compressible solvers which implement some pre-conditioning that do perform well for low Mach number flows.
Old   December 18, 2014, 22:02
Leeoo
Thank you, your reply was helpful for me!
solver, supersonic flow
Some results with a new compressible flow solver luca_g OpenFOAM Running, Solving & CFD 5 June 30, 2013 10:35
compressible flow in a duct - supersonic inlet mach number charndrabose_mit FLUENT 5 July 15, 2011 09:43
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 19:48
pre-conditioning for low mach number compressible flow solver Shenren_CN Main CFD Forum 0 April 29, 2011 21:07
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
