Temperature lower than possible in closed domain
Old   January 14, 2015, 07:59
Default Temperature lower than possible in closed domain
Cezary
Czarulla is on a distinguished road
I am working on transient model of natural convection with heat source inside the closed, cylindrical domain and one BC at the wall of cylinder. The BC is contant temperature of 323 K. Initial temperature of air inside this cylinder is equal to 350 K. After a certain time of simulation the temperature inside the lower part of cylinder fall down under 323 even to 293 K. Air is treated as an ideal gas. I have to mention that I also used S2S radiation model.
How is it possible for a closed domain to acquire from calculations a temperature, which lower than BC? Radiation heat transfer is also occuring from higher to lower temp? Could anyone explain it to me?
Best regards,
Czarulla
Czarulla is offline   Reply With Quote
Old   January 15, 2015, 06:01
Cezary
I checked that without using S2S radiation model temperature is reasonable.
Could anyone give me some tips how to appropriately set the S2S radiation model? I cannot set the free stream temperature as this is not the case.
closed domain, radiation, temperature bc
Setting Initial Temperature Of a Domain mjkey FLUENT 1 October 17, 2014 09:53
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Help: floating pressure, multiphase, closed domain memahfud FLUENT 1 September 24, 2009 04:38
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
