THE airfoil CP PLOT IN FLUENT IS JUST NOT POSSIBLE
Old   February 5, 2008, 19:27
Default THE airfoil CP PLOT IN FLUENT IS JUST NOT POSSIBLE
Rif
Hi, i'm running an airfoil simulation in the cfd code Fluent. After my solutions converged, i viewed the Coefficient of pressure plot for my aerofoil. The maximum Cp is more than 1. This does not make sense according to Bernoulli's equations. Can anybody help?
Rif
Old   February 6, 2008, 05:54
Default Re: THE airfoil CP PLOT IN FLUENT IS JUST NOT POSS
Charles
Did you set the right reference values? Also, depending on how far away your boundaries are, and exactly what BC's you specify, it is possible to get a horisontal pressure gradient effect that would show up in a slightly higher stagnation pressure coefficient.
Old   February 6, 2008, 09:15
Praveen. C
If it is compressible flow, then you can get more than one. Back to basic gas dynamics, read Anderson or some such book.
Old   February 6, 2008, 11:13
Rif
It is NOT a compressible flow. My density is constant.
Rif
residual spikes in fluent for airfoil case josip76 ANSYS 0 May 24, 2011 19:30
plot x,y on fluent Ricky FLUENT 1 May 27, 2009 06:18
Icing on Airfoil by using Fluent Saima Main CFD Forum 0 April 9, 2009 21:50
How to model suction flow in an airfoil in Fluent Davy FLUENT 4 October 23, 2006 03:56
how to creat a mesh in fluent for airfoil sanjay umarani FLUENT 0 March 7, 2005 05:26
