how to partition the multiblock mesh
Old   January 21, 2015, 20:45
Default how to partition the multiblock mesh
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
Do we have algorithms to partition the multiblock structured mesh for the parallel computation. During the partition process, we should not destroy the structured property of the grid system.
Regards
ztdep is offline   Reply With Quote
Old   January 21, 2015, 23:09
Michael Prinkey
mprinkey will become famous soon enough
Maintaining the block structure will be hard and will impact your ability to precisely load balance and to minimize/balance the communication overhead among PEs. Your options are limited to subdivision of your existing blocks and (depending on your code) transposition of your coordinate axes.
The easiest approach is to walk through your blocks in order and split them into subblocks along the slowest coordinate axis. I don't know how to describe the algorithm easily. Here is worked example partitioning three blocks of different size across 4 PEs assuming the z-axis is the slowest index:
https://www.dropbox.com/s/e9ez2yvsir...oning.pdf?dl=0
If you have the ability to transpose axes, you should spin them to have the largest dimension along the slowest index direction. That gives you the finest granularity when doing the block subdivision and thus get you the most even per-PE cell counts.
I don't know if there is going to be any gain for you from generating subblocks by slicing in more than one dimension. I guess it will depend on how much overhead and bookkeeping comes with the creation of (many) more blocks. If per-block overhead is not prohibative and since multiblock codes are essentially unstructured with regard to block interfacing, you might be able to cut your blocks into many tiny subblocks and feed that subblock topology into METIS and thereby get a more parallel efficient partitioning.
Good luck.
mprinkey is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
