March 2, 2015, 00:59 |
Oscillating Cylinder
yes
I am doing my final year project on cfd but my cylinder does not oscillates completely ie it oscillates only in the upper part and does not come down. Can Anyone find a way ouit to this situation??
March 2, 2015, 18:16 |
Sebastian Engel
Rep Power: 20 |
Please explain your problem in more detail. With this little piece of information hardly anyone can give you advice.
March 4, 2015, 02:16 |
yes
I am getting a error saying "a bodyNum is assigned to a non-Fress fluid cell"
March 4, 2015, 05:04 |
Sebastian Engel
Rep Power: 20 |
Unfortunately, this additional little piece of information is not sufficient to solve your problem.
In this forum most users help on voluntary basis. Being very unspecific often results in getting no answer at all. I would suggest you to explain your problem in greater detail and answer questions like the following: What do you want to do? How do you want to do it? Which Software (for Meshing and Solving) do you use? Which settings, models and boundary conditions? If your software is well known, consider posting in the right subforums. Add some pictures or/and your work files. ... etc. Right now, i only can suggest you to check your boundary conditions and your mesh... Probably not helpful at all. With regards, Sebastian |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 04:50 |
Oscillating Cylinder One Way FSI problem | vplpaul | CFX | 1 | August 20, 2013 18:59 |
Oscillating Cylinder in Parallel Flow: Analytical Solution | startingcfd | Main CFD Forum | 7 | March 23, 2012 05:49 |
problem with oscillating cylinder | zonexo | FLUENT | 3 | September 14, 2006 10:13 |
UDF for oscillating cylinder | fredD | FLUENT | 0 | July 16, 2004 09:32 |
