Wall heat flux BC in multiphase
Old   April 11, 2008, 13:26
Default Wall heat flux BC in multiphase
CFDtoy
In single phase flow, specifying Q can be used to computed T based on fourier law. When i specify Q for a multiphase problem, should i use the same Q for both phases (say 2 phases available)?? Even if i try to use modified conductivity as K=alpha*Ki (i=liquid or gas), the resulting temperature prediction becomes too high..
is there any model to specify Q for multiphase simulations??
Thanks,
CFDtoy
Wall Heat Flux & Temperature Greg Perkins FLUENT 10 November 20, 2015 09:32
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
Heat flux and k-e wall boundary conditions Blob CFX 4 June 8, 2009 05:10
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
Wall heat flux cujo CFX 3 November 6, 2002 03:43
