April 14, 2008, 11:33 |
Normal vectors to the curve
I am needing to find out the normal vectors to the curve to impose interface conditions in fluid-structure interactions. Could anyone give me hints?
April 14, 2008, 11:43 |
Re: Normal vectors to the curve
At the point of interest on the curve, find the tangent vector to the curve. Next find the (vector) radius of curvature, which is the first normal to the curve and lies in the local plane of the curve. Finally, find the second and last normal vector as the cross-product of the tangent and the radius of curvature. You can normalize all vectors to be unit vectors.
April 14, 2008, 14:30 |
assuming your surface is implicitely defined by a regular function (sufficiently smooth) F(x,y,z) = 0, then gridient of F at each point is equal to normal vector.
to determin tangential components of basis, pass a plan from your point based on your normal, then any two non-paralel vectors in this plan are two remained local basis, of cource when they are orthogonal your based will be orthogonal. |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
Integration Points and normal area vectors | Bloshchitsyn Vladimir | CFX | 0 | November 26, 2007 07:35 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
how to create a plane normal to a curve | Pei-Ying Hsieh | FLUENT | 0 | February 15, 2001 09:30 |
