April 15, 2008, 19:44 |
Interpolation related issue
Hi Everybody,
I try to trace particles in a reactor. Here the fluid flow is solved by FVM, and the motion of particle is solved by Lagrangian method. In order to calculate fluid drag force acting on particles, it requires the fluid velocity on particle position which is usually stored in the centre of CFD cell. Suppose I have already known the host cell where a considered particle is residing. Which method should be the best choice to obtain the fluid velocity on particle position from around CFD cells? For a quadrangular grid (2D), should I consider 9 cells (1 host cell + 4 neighboring cells + 4 immediate neighboring cells), or just 5 cell (1 host cell + 4 neighboring cells)? Your suggestions would be greatly appreciated? Regards, Kana |
Help on 2D interpolation in StarCCM+ | madhuri | Siemens | 1 | May 30, 2017 03:20 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 15:22 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 14:32 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 07:25 |
