in discontinuous galerkin method,a node varible may be shared by different cell,thus it has multivalues.because i want to plot a pressure isoline,and how do i treat the multivalues in the node in TECPLOT? thanks a lot
If your DG code is based on modal approximation, you can choose the piecewise-constant value at the cell center.
but i choose the nodal basis,the modal basis DG is underbuiding
Can I ask you something? Why did you begin with nodal based one? I wonder if there are differences between one another.
nodal basis belong to H adpapive,while modal basis can build P apdapive
Here is a suggestion.
Plot contours within each element. You could divide each element into smaller elements thus creating new nodes. Then set the solution at these nodes using the DG solution. Use these to plot the contours. The solution is discontinuous across elements. So you cannot any standard software. You can generate a contour data file which can be used with gnuplot. This way you will be able to visualize the discontinuous solution. See NS2KE for a subroutine which generates data for gnuplot contour visualization. |
Nodal bases produce natural sparse preconditioning matrices.
So, can you insist that one is superior than another?
#9 |
but where to get NS2KE?
#10 |
#11 |
thank you very much
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 09:55 |
How to export the specific heat and viscosity for postprocessing (compressible) ? | david39 | OpenFOAM Post-Processing | 2 | January 4, 2019 07:04 |
[pythonFlu] Postprocessing using pythonFlu + Matplotlib +Scipy | francois | OpenFOAM Community Contributions | 2 | June 21, 2011 11:26 |
Question about Postprocessing Using UDF(in tutoria | sarah_ron2002 | FLUENT | 1 | April 10, 2007 16:17 |
postprocessing | bas rijkse | FLUENT | 0 | July 5, 2001 08:30 |
